Caetano de Carvalho Rodrigues
Architect
Hello,
I've just installed the latest beta and I can't run it from inside photoshop.The installer didn't detect any installation of photoshop and I tryied to copy filter forge plugin files to photoshop plugins folder with no success. The filter name show up in the list inside photoshop, but when I try to use it I get an error message asking if I want to report a bug. Anyone has a solution for that?
Caetano Carvalho
You can try the following:
1. Go to the Filter Forge folder in the Plugins folder of your Photoshop.
2. Find the Filter Forge.config file.
3. Open the file.
4. In the IndependentUI line, if the value is false, change it manually to true.
5. Save the changes in the file and try running the Filter Forge plugin again -- this might help.
Architect
Hi gmm,
There was no filter forge folder in my photoshop plugins folder.
I've just unninstalled ff5 and deleted all remaining folders and reinstalled.
Now everything is working properly!
Thanks for your response!
Caetano Carvalho
15 unregistered users.
