I've attached a test filter. At the end of the chain before the result is an IF-THEN-ELSE component controlled by a Checkbox. If you change the value on the checkbox, the patterns leaving the THEN-ELSE part do not change. Unplug the inputs into the THEN-ELSE and change the checkbox. You will see the colors change.
Mac OSX 10.10.4, FF 5.004
if-then-else-test.ffxml
It's not a bug, it's cunning behavior of the If component.
It performs channel-wise comparison of the two source colors and generates the output based on this comparison. In your case the alpha channel of the Source A and Source B colors is identical, thus the result borrows its alpha from the Then input.
Yes, this is kinda counter-intuitive, I know smile:)
I wondered if it had something to do with shared alpha. In this case if-then-else looks elegant, but a switch is clearly more efficient. Curiosity said, let's try this...
14 unregistered users.
