In theory, this filter should show a pattern of single-pixel dots 4 pixels apart without the Offset component. However, it requires an extra (miniscule) offset to read the correct pixel.
Although the Free Rectangle is set to start from 0,0 and end at 1,1, it does not show up at the pixel coordinate 0,0, requiring an offset to push the rectangle over ever so slightly so that it overlaps the 0,0 point.
Don't know which Component is causing this, Free Rectangle or Lookup or Pixel X/Pixel Y or the combination thereof, but the combination errs just to the wrong side of the exact coordinate, reading 0,0 point as not being on the rectangle.
Pixel Coordinates + Lookup.ffxml
It took us some time to figure out what's happening here. Your example can be simplified to Free Rectangle plugged into Lookup: the (0,0) and (1,1) points really belong to the background and not to the rectangle.
The reason is that the endpoints are excluded from the (0,1) interval. This is not a bug but intended behavior, you just need to keep this in mind when designing filters. Frame (and possibly certain other components) also behave this way.
Vladimir said it is possible to change the logic and include the endpoints in the interval, but, frankly, we have more urgent things to implement.
19 unregistered users.
