With beta stage 2, we could have some examples of what can be done with the new pixel-based components that has been way more difficult before.
Here's Windows 8 Window.
Likely better methods to achieve the same result exist. This is my first test.
Windows 8 Window.ffxml
Like so:
YES, I agree, although this seems to be an interesting and useful thing, would be great to have more information and examples on how this can be used and what to use it for, as I do not have ideas on how can I get benefit from this
16-bit patterns
Binary 4x4 patterns generated from the numbers 0-65535. Just set pixel size and randomize.
16-bit patterns.ffxml
And you get things like this.
The new Modulo Components used heavily herein as well.
Spaceray wrote: would be great to have more information and examples on how this can be used and what to use it for
Just about everything in web design and interface design is pixel-based to maximize sharpness and to retain the sizes of certain features regardless of scaling. Icons, buttons, window corners, text, background patterns, images -- almost everything retains a certain pixel size in one or more directions despite resizing the browser or application window. (Unless you zoom in.)
Pointer
Pixel-sized pointer with color control for picking position.
Pointer (Pixel-sized).ffxml
As in:
Really Great examples ThreeDee.. smile:)
Scanlines
Basically, alternating bands of color (or images), with the width of the bands in pixels.
Scanlines.ffxml
Two images can be combined this way.
(I shrunk the images before applying the filter, because the forum has a max upload size limit)
Cool. You could also do de-interlace.
The 16-bit patterns filter had a precision error with a white line appearing between blocks at larger pixel sizes. Fixed here.
Hum interesting. Tried making a mini pixelation filter using the new Pixel XY and Width/Height components. Nothing hyper exciting, just a thought. lol albeit, kinda like a lame duck given you can just use profile gradients for this to work lol.
Pixel XY Pixelation.ffxml
Good news: I made a pixel-based inner distance transform in FF with the new components.
Bad news: This 64x64 image, with 6 iterations (distance=7) took over 10 minutes. The result is accurate, but someone please tell me they have a faster method. smile:|
Indigo Ray, I did work on something related once, see this discussion. It is not pixel based though, but with a little pre-post scaling I belive that should be achievable.
Thanks for the link, Sphinx. I had never seen that thread before. Still not sure how the bitmap components' radii correlate to actual pixels. But wow that's a lot faster. I read somewhere on the web that my algorithm is considered brute force and one of the slowest ways to do it. Well hey, I'm not a paid programmer! smile;)
Pixel Bevel
Single-pixel-width bevel, with rotatable angle.
Pixel Bevel.ffxml
Example (click on the image to view at the proper resolution).
Something that I was working on in version4 is much easier in FF5...Similar to scanlines but with other elements...
This is probably a more appropriate place for this anyway...
No, you didn't! (Did you?) smile:eek:
You should render a 20000 pixel tall version, post it in the AE forum and ask what's wrong with your project. smile:dgrin:
"Can we change how fast the logo comes in?" smile:cry:
Here's the filter tree. It looks like a futuristic spaceship smile:D
(At the bottom you can see some mixed keyframes that I still need to implement properly)
Hehe. The moment you realize you probably should not have animated all 52 pieces thereof separately and manually...
Just gonna leave this here...
With some styling and pixel-subsampling...
Reminds me of the old ADM 3A terminals... I'm showing my age. smile;)
Someone was going to do it eventually... I especially like the styling, Betis! However, there's a minor error in your character-matching algorithm, which I fixed manually. I'm surprised you didn't catch it, I found it within 5 seconds. smile;)
Playing with your Scanlines, here is Weavelines:
And the filter.
Weavelines.ffxml
LexArt
LexArt
I have just found this thread and want to thanks for the many shared pixel based filters
but the problem I see with this is that I have seen that you can´t use with the result of pixel awareness with any of these components
Any transform components (Flip, Offset, Rotate, Scale)
Kaleidoscope
Bomber and Bomber +
Noise distortion
It seems that it does not work with any component that will try to modify the pixels positions
So you can use it only with vertical and horizontal lines?
Or the same vertical and horizontal lines rotated 45 degrees as shown well by Rick Duim in this other thread
How can Pixel Awarness be used for rotated grids and thicknes?
