xirja
Idididoll Forcabbage
Modulo doesn't accommodate negative divisors:
Bug Negative Modulo.ffxml
You can use negative divisors but the remainder will always be positive. This component was designed to replicate the output of LUA's modulo function. Please check the attached filter to see the component works as intended.
ModuloScript.ffxml
14 unregistered users.
