jvansyckle
Crash and exit using "Flatten Lightness" filter.
Model Name: iMac (Retina 5K, 27-inch, Late 2014)
Model Identifier: iMac15,1
Processor Name: Intel Core i7
Processor Speed: 4 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 24 GB
Boot ROM Version: IM151.0207.B00
System Version: OS X 10.10.1 (14B25)
Process: Filter Forge [14519]
Path: /Applications/Filter Forge 5/Filter Forge.app/Contents/MacOS/Filter Forge
Identifier: com.FilterForge.FilterForge5
Version: 4.0
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: Filter Forge [14519]
User ID: 501
Date/Time: 2015-01-07 08:20:52.264 -0500
OS Version: Mac OS X 10.10.1 (14B25)
Report Version: 11
Anonymous UUID: DCAAD98D-D640-D1DC-A777-7C86B4B55CC5
Sleep/Wake UUID: 871BDC4D-514C-481A-AF86-F8B5C70421D7
Time Awake Since Boot: 76000 seconds
Time Since Wake: 160 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000088838d00
VM Regions Near 0x88838d00:
__LINKEDIT 0000000050535000-000000005054b000 [ 88K] r--/rwx SM=COW /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
__TEXT 000000008fe99000-000000008fecd000 [ 208K] r-x/rwx SM=COW /usr/lib/dyld
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreGraphics 0x9886c24c assert_check_shape + 19
1 com.apple.CoreGraphics 0x9886d731 assert_check_region + 73
2 com.apple.CoreGraphics 0x98871bc2 CGRegionIsEmpty + 22
3 com.apple.HIServices 0x938be18d HIShapeIsEmpty + 24
4 com.apple.HIServices 0x938be5a1 CreateIntersection(__HIShape const*, __HIShape const*, CGSRegionObject**) + 36
5 com.apple.HIServices 0x938be8cf HIShapeCreateIntersection + 35
6 com.apple.HIToolbox 0x9b5bd4d0 HIView::BuildAggregateInvalidRegion(__HIShape*) + 346
7 com.apple.HIToolbox 0x9b5bd3d6 HIView::BuildAggregateInvalidRegion(__HIShape*) + 96
8 com.apple.HIToolbox 0x9b5bd3d6 HIView::BuildAggregateInvalidRegion(__HIShape*) + 96
9 com.apple.HIToolbox 0x9b5bd3d6 HIView::BuildAggregateInvalidRegion(__HIShape*) + 96
10 com.apple.HIToolbox 0x9b5bd3d6 HIView::BuildAggregateInvalidRegion(__HIShape*) + 96
11 com.apple.HIToolbox 0x9b6831e8 HIView::DetermineAreaToPaint(OpaqueGrafPtr*, unsigned long, __HIShape const*) + 40
12 com.apple.HIToolbox 0x9b68294e HIView::DrawComposited(short, OpaqueGrafPtr*, __HIShape const*, unsigned long, HIView*, CGContext*) + 146
13 com.apple.HIToolbox 0x9b682870 HIView::Draw(short, OpaqueGrafPtr*, unsigned long) + 84
14 com.apple.HIToolbox 0x9b682814 HIView::Render(unsigned long, CGContext*) + 46
15 com.apple.HIToolbox 0x9b5c5514 FlushWindowObject(WindowData*, void**, unsigned char) + 883
16 com.apple.HIToolbox 0x9b5cfe5a FlushAllBuffers(__CFRunLoopObserver*, unsigned long, void*) + 251
17 com.apple.CoreFoundation 0x94fdd40e __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 30
18 com.apple.CoreFoundation 0x94fdd350 __CFRunLoopDoObservers + 400
19 com.apple.CoreFoundation 0x94fce679 CFRunLoopRunSpecific + 361
20 com.apple.CoreFoundation 0x94fce4fb CFRunLoopRunInMode + 123
21 com.apple.HIToolbox 0x9b5c7178 RunCurrentEventLoopInMode + 262
22 com.apple.HIToolbox 0x9b5c6d83 ReceiveNextEventCommon + 192
23 com.apple.HIToolbox 0x9b76c798 ReceiveNextEvent + 90
24 com.FilterForge.FilterForge5 0x0072e5da Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 1648
25 com.FilterForge.FilterForge5 0x00734c76 Controls::FormProcessingTask::invoke(XFW::OS::Environment&) + 68
26 com.FilterForge.FilterForge5 0x0098e377 FFXLib::Round2::get_class_info() const + 1815
27 com.FilterForge.FilterForge5 0x0098e524 FFXLib::Round2::get_class_info() const + 2244
28 com.FilterForge.FilterForge5 0x00730cb2 Controls::ScrollPreviewTask::invoke(XFW::OS::Environment&) + 11592
29 com.FilterForge.FilterForge5 0x00074fe2 XFW::Events::EventInvokeAdapter<FFX::FileProcessingForm, Controls::KeyboardEventArgs const>::clone_object() const + 3906
30 com.FilterForge.FilterForge5 0x0019a715 XFW::Events::EventInvokeAdapter<FFX::LightingSettingsPanel, Controls::MouseWheelEventArgs>::clone_object() const + 17527
31 com.FilterForge.FilterForge5 0x009af458 XFW::Helpers::CheckFailed::clone_object() const + 3946
32 com.FilterForge.FilterForge5 0x009b099d XFW::Helpers::CheckFailed::clone_object() const + 9391
33 com.FilterForge.FilterForge5 0x009b4a8e XFW::Localization::LanguagesStorage::~LanguagesStorage() + 118
34 com.FilterForge.FilterForge5 0x00002a16 0x1000 + 6678
REGION TYPE VIRTUAL
ATS (font support) 33.1M
ATS (font support) (reserved) 4K reserved VM address space (unallocated)
Activity Tracing 2048K
CG backing stores 12.8M
CG image 320K
CG shared images 560K
CoreAnimation 2980K
CoreGraphics 12K
CoreServices 388K
CoreUI image data 340K
Foundation 4K
IOKit 5364K
Image IO 4K
Kernel Alloc Once 4K
MALLOC 264.0M
MALLOC (admin) 48K
Memory Tag 242 12K
OpenCL 52K
OpenGL GLSL 128K
Stack 30.9M
VM_ALLOCATE 19.3M
__DATA 12.0M
__GLSLBUILTINS 2588K
__IMAGE 528K
__IMPORT 108K
__LINKEDIT 52.4M
__OBJC 4140K
__TEXT 178.4M
__UNICODE 544K
__UNIXSTACK 64.0M
mapped file 168.0M
shared memory 68K
TOTAL 854.6M
TOTAL, minus reserved VM space 854.6M
Model: iMac15,1, BootROM IM151.0207.B00, 4 processors, Intel Core i7, 4 GHz, 24 GB, SMC 2.22f16
Graphics: AMD Radeon R9 M290X, AMD Radeon R9 M290X, PCIe, 2048 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384B54463531323634485A2D314736453220
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x873E, 0x4C49464554494D454D454D4F52592E434F4D
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x873E, 0x4C49464554494D454D454D4F52592E434F4D
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x142), Broadcom BCM43xx 1.0 (7.15.124.12.10)
Bluetooth: Version 4.3.1f2 15015, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE SSD SD0128F, 121.33 GB
Serial ATA Device: APPLE HDD ST1000DM003, 1 TB
USB Device: Expansion Desk
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: OneTouch
USB Device: Hub
USB Device: HL-3170CDW series
USB Device: CTH-661
USB Device: Apple USB SuperDrive
Thunderbolt Bus: iMac, Apple Inc., 26.1
16 unregistered users.
