Sharandra
Filter Forge Addict
No clue by what it is caused, but the rendering inside the editor fails to render quite often. It either renders only part of the image, or doesn´t even start. To get it to render again I have to lock preview to a different node, then switch back.
In the attached screenie you can see how it didn´t render part of the image. The green part was rendered before I opened the editor.
Sorry, not enough information to reproduce that.
Sharandra
Filter Forge Addict
What information do you need?
Rendering inside the editor works correctly for me. Please provide detailed steps on reproducing this issue reliably.
Sharandra
Filter Forge Addict
I can´t, because it happens randomly as I wrote in my first post.But it happens, else I wouldn´t have reportet it. It might have been caused by the thumbnail/filter caching, as it happens less now, that it seems to be mostly through with that.
