Alright here's something.
FilterForge allows me to rename a folder no problem the first time when I open the program. After that, I can't rename it no matter what I do.
Here's a video of it happening:
https://dl.dropboxusercontent.com/u/83...rename.mov
I'm currently running MacOSX 10.9.
Please let me know if there's anything else needed. smile:)
I have tried this on Windows 8 and this does not happen, I can rename a subfolder of custom filters any time, so it must be something only on the Mac side.
Well I'm certainly glad it works on Windows.
SR, this bug report is for a Mac as specified. If it works nicely on your PC, you don't need to report that. That post's just redundant.
Sorry, but this is not put under the MAC bugs and problems, is put in the Beta 4.0 part of the forum, so you can´t know that this is Mac specific, I would not have tried it myself if it was in the Forum of Bugs and Problems (Mac)
I wrote MacOSX buddy. Least you're confirming something.
ddaydreams
Frank Hawkins
works fine for me Windows 7 64bit
Sorry, does this mean that as you have a bug in your Mac, this bug can´t happen in the same way in Windows?
Because there are some bugs that happen in both Windows and Mac and not only happens in one or another
maaan... I feel like I'm just leaving hiccup posts. Sorry folks. Sometimes, I run out of patients.
Yeah. I tested it on Windows and it doesn't happen. At least from how long I've played with it.
Well, if you have tested yourself already on windows you could have put it already in the first post, unless you tested it after doing the post
Yeah the whole Windows thing came later. smile;)
Thanks Skybase, we confirm the issue. There is a workaround: if you hit Enter after typing the new name (instead of clicking somewhere else) the issue doesn't appear.
A bug point for you.
Aye! Thanks for the workaround smile:) Will use that for now.
11 unregistered users.
