Sharandra
Filter Forge Addict
If you rename a folder in My Filters, just changing a lower case letter to upper case, it says " folder with the name already exists" and won´t change it.
This is by design (though I admit it may be unusual).
When you rename a folder inside FF it doesn't invoke the API function for renaming. Instead it tries to create a new folder and move all contents into a new folder. Obviously it is unable to create a new folder in your case.
13 unregistered users.
