Sharandra
Filter Forge Addict
Totally love the ability to create folders and organize my filter library! smile:-)
But it is very laggy and often unresponsive. Sometimes the cursor vanishes behind the FF Window, sometimes when renaming, it doesn´t show in the text field.
Or it won´t let me drag and drop a filter into a new folder.
I keep having to restart the program every few minutes because it hangs.
Edit:
small bug: if you rename a folder, just changing a lower case Letter to Upper case, it says " folder with the name already exists" and won´t change it.
And another one: If I add a subfolder to "Custom filters" and then create a new folder somewhere and type a name for it, it ignores that and picks a different folder.
I mentioned that in the official thread, when dragging and dropping filters from Custom folders and Favorites, it doesn´t remember the previous position in the list like it does in the filter Library folders. a bit annoying having to scroll down to wh ere you just were all the time. smile:-)
When dragging a filter to another folder, it doesn´t select the filter you just dropped, instead it selects the last that was added before.
Folders collaps/uncollaps randomly
Sharandra
Filter Forge Addict
No idea how this happened or if it´s reproducable:
I just created a subfolder under one of my Favorite folders. the program froze and I restarted it after waiting a while.
After the restart, the folder, which contained the new subfolder, had changed it´s name to the one of the subfolder.
Gill Brooks
GillB
I've had no problems at all creating new subfolders and moving my favourites into them.
However, you could try manually editing the Favourites.xml file in AppData (when FF is not running)
When you open the file you'll see a list of your favourites as one long list. Go to the last one in the list and add the category name and location. Here's an example
<Category name="Edges" location="My Favorites/Edges">
<Filter path="Library_3676"/>
<Filter path="Library_7571"/>
</Category>
<Category name="Grunge" location="My Favorites/Grunge">
<Filter path="Library_7811"/>
<Filter path="Library_1660"/>
</Category>
<Category name="Paint FX" location="My Favorites/Paint FX">
<Filter path="Library_5355"/>
<Filter path="Library_4245"/>
</Category>
</Storage>
Gill
12 unregistered users.
