I have used a snippet and then when trying to connect it to the bomber it tells me that I should use the particle adapter, and then I use the particle adapter AND STILL tells me that I should use the particle adaptor? smile:?: smile:?:
I am doing something wrong? or is it a bug?
And what is more curious is that the warning in the Particle adapter tells me that it does not make sense to use the particle adapter when the other warning is telling me to use it
Here is the filter that I have done
Please, is something I have done wrong, or what is wrong is filter forge editor?
I have the latest version of FF 4.0
Particle Adapter Warning.ffxml
Any reason why you're using the fancy old method of creating polygon shapes? smile;) You remind me of the epic days when filters got so big haha. It's a cool way though....
Here's a solution to the issue.
SpaceRay, weren't it you who posted multiple messages about that in September? This has been fixed but not published yet -- the fix will be available in the next beta update.
Thanks for the updated filter, will see it
Well, the reason is that I am using the shapes snippets available in the library and all these may be from FF 1.0 as they have not been updated.
Sorry I thought that this was already fixed in the last minor update, but then if if you say that it has not been fixed yet, it seems that it was only fixed the color control problem and I am wrong that it was already fixed this warnings, will wait for it on the next update
FF 4.05 Color control bug when activating "allow images" crashes FE
I have been seeing your updated filter, Skybase and I thought that all was the same as the original filter, until I have seen this shown below that you have used the particle adapter after the Frame component, I did not know that it could be used in that way too, I have only used it when connecting something to bomber.
Honestly more like a workaround than a solution.
You can use the particle adapter where needed to produce bomber-friendly sources. But given that it's an "adapter" it's probably preferred that it'd be used before the source enters the bomber. Not that there are rules against it.
[edited]
Thanks, well, it has solved and fixed the warning problem that I had so this is all that was needed and even I agree this is workaround, it works right, so is enough.
Yes, you are right there are no real rules against using the particle adapter on other parts of the filter that are not just before entering the bomber to make it bomber-friendly, and it did work well.
Any reason why you're using the fancy old method of creating polygon shapes? You remind me of the epic days when filters got so big haha. It's a cool way though....
Old method of creating polygon shapes?
Is there a NEW method better and optimized way to do it?
As said I have not done it myself, is just this Polygon V2.0 by uberzev snippet, but was released in 2008, so there could be newer ways that could be done in 2013 with FF 3.0 or FF 4.0
I have remembered now that you have a great simplified way of creating shapes when you made the awesome and excellent Gradient Shapes
==== slightly off topic now====
"Old" as in methods introduced in 1.0 to compensate requests back then.
Polygon/Ellipse components were introduced back with 2.0! Did you... forget about them?
Also, the introduction of HDR/non-seamlessness/RGB math made some of the 1.0 technical snippets obsolete methods. And yes, if you want to build a polygonal shape from scratch, new versions allow for more concise methods for constructing, so a lot of those components can be condensed to 1 or 2 components.
I'm just saying it's interesting you're picking up a method from the 1.0 era to generate polygonal shapes when we already benefit much more from the provided poly/eclipse components. Most optimized = what's readily available as a component. But I'm not saying that 1.0 snippets lost their value completely. They're nice technical reminders of what we had to do to generate stuff back then and also some inspiration. Though as a guy who makes filters, I never liked the whole thing with having "obsolete" components in the newest filters. Just something uncomfortable about them.
For bonus points you should: using techniques from the 1.0 era and using only what was available back with 1.0, add a full 360 rotate function to the polygon snippet. smile;)
I understand know what you mean smile:)
OH!! smile:blush: I am very sorry that I forgot totally that FF 1.0 did NOT have the polygon/Ellipse components and have been thinking that these were already available in FF 1.0 and then I was totally focused on the shape snippets and was confused thinking that this was the only way to make them, and forgot totally that would be much easier to make some of them with the available polygon component smile:blush: smile:blush: I do not know how I could forgot to make the shapes with these new components? smile:( smile:blush: I will rebuild the filter using these ones instead of the old method.
Thanks for bringing me to the real, actual and modern world of FF smile:D
Yes, I agree they are not totally useless, because as you say very well, you can still now learn some things from them and how they are built, AND also some of these snippets have additional shape generators that can´t be done directly with either polygon/elipse components.
Actually you can do everything the snippets display using polygon/eclipse components. I certainly feel they're all doable!!
Yes, you are right, I agree and think also that most of the FF 1.0 snippets can be also done with Polygon and elipse, but as you have said well, must be done with other additional components and so this is why I have said
I mean without needing any other component for getting the same result
13 unregistered users.
