Sharandra
I attached a filter which shows this problem. If you take two perlin noises with different angles and mix them in a pattern, the normal map will be weird and it looks wrong on a model.
perlin normal weirdness.ffxml |
| Posted: September 17, 2013 11:32 am | ||||
Sharandra
| Posted: September 17, 2013 11:36 am | ||||
Administrator |
I don't see anything wrong with the filter. However, it uses high-frequency noises, so the weirdness you're seeing might be caused by aliasing.
Try to render the normal map with Anti-Aliasing set to All Pixels, 65 samples per pixel, and see if the result looks better on a model. When exporting the normal map, use lossless compression if possible (PNG24 or similar) to rule out compression artifacts. |
| Posted: November 11, 2013 9:01 am | ||||
Sharandra
Sorry, I missed your reply.
It´s not artifacts or antialiasing. It´s the lighting that is weird. One part of the map will always appear flat, like the left side on the example image. |
| Posted: December 10, 2013 11:43 am | ||||
I have tested your filter and I get the same result as shown above, so it happens to me too, both parts look different
I suposse that what you want is to have BOTH having exactly the same look and does not look different as they are showing, so both parts are the same. |
| Posted: December 12, 2013 3:59 am | ||||
12 unregistered users.
