Sharandra
The particle adapter doesn´t work inside a group with incoming color controls. It only works if connected outside the group.
| Posted: August 30, 2013 3:25 pm | ||
Yes, you are right, I have tested it and there is something weird there. Maybe this is not a bug, and the right way to use the particle adapter is outside of the group.
I have made a filter to show it what really happens, please download the attached filter At the top of the filter is the original filter I have made before for the FF Library PARTICLE ADAPTER INSIDE GROUP: Below original filter I have made a group with the particle adapter inside the group and it gives a warning message, when in the original filter there is no error. PARTICLE ADAPTER OUTSIDE GROUP: After this, the third part show the group with the particle adapter outside the group and it work right without warning message Particle Adaptor Warning inside group.ffxml |
| Posted: August 30, 2013 3:47 pm | ||
| Posted: September 2, 2013 4:00 am | ||
65 unregistered users.
