JesusSheep
Posts: 87 |
| Posted: April 5, 2013 1:43 am | ||
Administrator |
What is "Loop Control"? Could you please post step-by-step instructions for reproducing this, plus any filters involved?
| Posted: April 5, 2013 9:03 am | ||
Yes, there is not enough information to be able to know what is the error and why is this happening, as said by Vladimir, would be good to know what you have done just before this happened, so it could be reproduced and be able to see what may be wrong.
| Posted: April 5, 2013 11:04 am | ||
JesusSheep
Posts: 87 |
Load an image in program
Take out the Exteral Image component. Drag out the Loop Component Press Add Accumulator Press Add Interator Connect Image to Accumulated Press add Position Set Imterations to 99999 Because of Lack of documentation unable to make real test |
| Posted: April 5, 2013 11:50 pm | ||
Just did all the above with no crash....But there are a lot of questions such as what filter were you using and was this a newly created filter?....Set Iterations of the main loop?....
What type of image did you open and at what size was that image? Did it have a transparent background?........Sometimes that also makes a difference.... What you have is what does happen when there is a crash.... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: April 6, 2013 12:39 am | ||
I agree with CFandM that there are still a lot of questions unanswered to be able to reproduce this to have the same crash.
Perhaps one good way would be that you upload the filter with the loop you have already and tell us how to use it, and what image to load, and when does the crash happen, I mean with what settings or when. Are you using the FF 4.03 with the hotfix? from the instructions you have given I have only been able to get what is shown below in the screenshot How do you connect the components in the same way that you have done to get the crash? Or as suggested already above, would be easier that you upload the filter with the loop and slaves already connected |
| Posted: April 6, 2013 12:48 am | ||
15 unregistered users.
