Daydream
Daydream
Hi everyone,
Just reporting that a number of filters from the filter gallery are no longer working in FF4.0 Beta 2 / Win8 Pro / Photoshop CS6 64 bit.
Here is an example filter: http://www.filterforge.com/filters/8386.html
And this is how it appears in FF for me: http://i.imgur.com/B9YOhrB.png
This is just one filter out of many that I've tested and have found not to work correctly.
Any thoughts? I'd like to keep using the 4.0 beta but I will have to go back to 3.0 until this is resolved.
Mardar
Graphics Junkie
Filters: 61
I posted about a problem very similar to this a couple of days ago. I'm having trouble with the checkbox control. Now all my older filter will not work if they have this control in it. Here is my post. http://www.filterforge.com/forum/read...&TID=11137
Everyone, please post broken filters here. This is important.
Mardar
Graphics Junkie
Filters: 61
Mardar
Graphics Junkie
Filters: 61
http://www.filterforge.com/filters/8982.html
Found one more. This last one has the problem in the IntSlider control.
Mardar
Graphics Junkie
Filters: 61
I found a work around for the "checkbox control". I checked the remapping option and set the "checked" box to 180 degree and the "unchecked" box to 270 degree. It is working with these settings. Only seems to be bad in the 0 Degree and 90 degree setting. Not sure if this will help programers or not. smile:)
Daydream
Daydream
Cube Wall - Strange artifacts / tearing on sides of cubes
http://www.filterforge.com/filters/11298.html
http://i.imgur.com/us2i0vF.png
Unfortunately that issue is in the filter itself, due to Smudge limitations, not due to program version.
xirja
Idididoll Forcabbage
Can see explicitly that the last preset in:
Variable Kaleidoscope
http://www.filterforge.com/filters/10216.html
is different from 3 and 4 beta 1 to beta 2.
moradin2013
moradin2013
An effect filter/pattern seems defective:
http://www.filterforge.com/filters/7992.html
Works first time, but add new image at 3000 x 3000 and the pattern is like barely created. All changes of image size after do not restore it to its full function.
moradin2013
moradin2013
Forget about the previous post...
smile:blush:
