MS Photo Artist
Posts: 5 |
When I attempt to use Filter Forge Pro Beta 4.002 in the 64bit version of CS6 I get a "CS6 Has Stopped Working"... error message. I restarted my computer but that did not fix the problem.
Beta 4.002 works fine in the 32bit version of CS6. |
| Posted: March 2, 2013 7:17 am | ||
MistaD
Posts: 1 |
Same here, didn't try 32bit however
| Posted: March 4, 2013 7:52 am | ||
Akimotos
Posts: 5 |
i can run filter forge 4.002 in CS6 32bit, but not in CS6 64bit
and when starting and closing filterforge i also get errors. I tried running it normal and under administrator. Application pop-up: Filter Forge x86.exe - Application Error : The instruction at 0x00e05283 referenced memory at 0x00000000. The memory could not be read. Paul |
| Posted: March 4, 2013 5:47 pm | ||
joBox
Yep, same here. CS6 with the newest FF4 = crash & burn EVERY time
joBox |
| Posted: March 4, 2013 7:32 pm | ||
| CeleriedAway |
+1
| Posted: March 4, 2013 9:22 pm | ||
Is true, it happens to me also, if I want to use FF 4.02 as a plugin with Photoshop CS6 Extended 64 bit, in the moment I sel ect it, it crashes photoshop "CS6 Has Stopped Working"
using Windows 7 64 bit I have deleted and resinstalled FF 4.02 again fresh and it does not work as plugin, perhaps could it be that you need to delete all the additional data fr om the FF 4 folder? I do not know what happens |
| Posted: March 5, 2013 12:11 am | ||
Thrash
Posts: 78 |
Ditto to everyone & everything said. CS6 64bit is El Bombo.
| Posted: March 5, 2013 3:35 pm | ||
I have tried more to see if it happens always or sometimes don´t, but from 5 tests with different images and ways, in all I have got the Photohop crashing.
Just load any image and then go to Filter--> Filter Forge --> Filter Forge 4 = Crash |
| Posted: March 6, 2013 2:58 am | ||
Bongo
Posts: 15 |
| Posted: March 6, 2013 4:18 pm | ||
Yes, Bongo, you are right, I have confirmed that it also happens the same in CS5 so it happens in both versions.
| Posted: March 6, 2013 11:34 pm | ||
Posts: 3507 |
Please download this file:
http://www.filterforge.com/download/s...%20x64.8bf and copy it (replacing the existing one) into this folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\Filters\Filter Forge 4\Filter Forge 4 x64.8bf |
| Posted: March 7, 2013 3:31 am | ||
Thanks very much GMM for the new plugin file, I have tried and it now works right
| Posted: March 7, 2013 5:50 am | ||
Bongo
Posts: 15 |
Wow thanks GMM it works for CS5 also.
Jerry |
| Posted: March 7, 2013 6:32 am | ||
joBox
THAT was quick!! Thanks for the fix
| Posted: March 7, 2013 8:58 pm | ||
horbie_lb
Posts: 1 |
I just saw your info and it solved my problem on CS5 now. Thank you GMM!
| Posted: March 9, 2013 5:35 pm | ||
Amy Hutton
Posts: 26 |
Will this fix work for Paintshop Pro X4? I haven't been able to use Filter Forge for many months and it is SUPER frustrating. I, too, have a 6 core 64 bit machine.
If so, how would I do that? I would LOVE to have my FF back. Playing with images is one of the only things that relaxes and inspires me! Amy Hutton |
| Posted: April 10, 2013 4:11 pm | ||
Posts: 3507 |
Amy, have you tried these instructions?
| Posted: April 11, 2013 6:27 am | ||
