Mojo3
Posts: 12 |
Hello all,
Ok, I found another small issue in Filter Forge 4.002 standalone on Windows 7 32 bits. 1. I have set one of my jpeg files as hidden. 2. Windows Explorer sees the file (I have set the preferences so that it sees all hidden files and folders on the computer). And Filter Forge sees it too. So I load the image into Filter Forge. 3. I apply any filter on the loaded image. 4. When I try to save the image with the same name and at the same location, I get the following error message from Filter Forge : "::CreateFileW(file '[...].jpg') failed with error code 0x00000005: Access is denied." Doing the same with Microsft Paint (in accessories) works... So it has to work in Filter Forge as well probably. This seems to be a common issue with many softwares (Google it!). For example see: http://superuser.com/questions/155896...dden-files Best Regards |
| Posted: January 7, 2013 1:31 pm | ||
Thats a windows issue not a FF issue....When files are hidden some apps will not work with those files nor will they open them....
| Posted: January 7, 2013 9:09 pm | ||
Posts: 3507 |
CFandM is right: this is not a Filter Forge issue.
| Posted: January 8, 2013 3:47 am | ||
90 unregistered users.
