JimK
Tried installing the beta in a non-default folder. Selected "Custom" under location to install into, then selected a subfolder under the Applications folder. Only the app file installed in that folder, nothing else. When I tried to run it FF generated an exception message as it couldn't find the necessary .xml file.
I then installed it using the default location in the Applications folder and everything installed correctly and the app started up correctly. I then moved the entire FF4 app folder into the other subfolder and it opens correctly know.
Bug report also filed with the exception message.
Jim in Atlanta, GA
What OS version do you use?
JimK
Mac OS 10.8.2
Running on a Macbook Air.
Jim in Atlanta, GA
Thanks for the report, we've reproduced the issue.
58 unregistered users.
