| CeleriedAway |
Hello Everyone!
My today's experiments ended up with a disaster. I tested one script, for the test I put it in a group and copied it several times, then I connected group input and output to each other. In some moment FF crashed. I have not cought wich action i made last but I can't even open filter forge now With this 'destructive' filter in a library filter forge crashes a lot just by clicking on any filter that has map script component (or may be not, I didn't fully recognize pattern of crashes), its hard to work now. I don't even know how to remove or restore this filter if a single click kills app. Here is the file with filter, be carefull with this. I couldn't send bug report because chrome says that "No bug report info found" after I tried to submit it. Anyway I think its easy to reproduce this bug just by loading filter. [FFXLib::RenderingContext] Failed to load filter My Filters_offset calculator. [FFXLib::RenderingContext] Failed filter dump: .... my filter xml here [Controls::Control] Exception occured while processing window message 0x00000201(WM_LBUTTONDOWN) (0x00000001 0x015200B6) for window 002C0F5C/002C0F5C, control: <class Controls::ListBox>@03B64D18. Exception caught at thread 000029CC 'Application': <class XFW::StateError> Unable to create a second instance for single instance class ScriptMap01. <unknown file>(0) : <unknown function>()+0 at 006B61CA in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 006B1E27 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00409E7B in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 006B985F in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 006B4820 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 006B484E in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00412DFC in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0076F9FC in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00409E7B in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0076134E in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 006BBEC7 in Filter Forge x86.exe CONTEXT_CONTROL: CS:EIP 0023:75A6B9BC, SS:ESP 002B:0018C568, EBP 0018C5B8, FLAGS 00200212 CONTEXT_INTEGER: EAX 0018C568, EBX 0435FB80, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 0018C5F8 CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B offset calculator.ffxml |
| Posted: September 30, 2012 11:13 am | ||
You should be able to remove the offending filter (as long as you can open FF) by selecting Filter>Locate File, which opens your "My Filters" folder and then removing the filter from there.
Or, if you can't open FF, navigate to the folder at C:\Users\[your user account name]\AppData\Roaming\Filter Forge 4\My Filters (on Windows) and remove the filter that way. |
| Posted: September 30, 2012 2:14 pm | ||
120 unregistered users.
