Sharandra
Filter Forge Addict
<class XFW::StateError> Unable to create a second instance for single instance class ScriptMap01.
Made a group containing a mapscript, created a second instance. All working fine. Then I clicked on save and it crashed. Can´t open the filter anymore aswell, instant crash.
Steps to reproduce:
1. grab a mapscript component
2. group it
3. copy it
4. save filter
5. crash
no crash if you detach the copy from instancing.
Bionic
Similar happens with Curve Script, FF will not start after this unless I delete filter from my profile folder.
Code
Operating system:  x64 Edition (6.2 build 9200)
Physical memory: 8068 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7-3770K CPU @ 3.50GHz, ~3475 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [2012-09-17 07:57:15 W. Europe Daylight Time]
[FFXLib::RenderingContext] Failed to load filter My Filters_12345.
[FFXLib::RenderingContext] Failed filter dump:
<?xml version="1.0" encoding="utf-8"?>
<Filter>
   <CustomClasses>
      <MapGroup name="MapGroup01" display_name-en="">
         <Color name="groupped_colormapcontrol_01" display_name="Noise" hdr="false" required="false"/>
      </MapGroup>
      <Sc riptCurve name="ScriptCurve01" display_name-en=""/>
      <Sc riptCurve name="ScriptCurve02" display_name-en=""/>
   </CustomClasses>
   <Components>
      <Result id="result">
         <Source source="mapgroup01 01"/>
         <FilterType value="0"/>
         <Lighting>
            <Height value="0.20000000000000001"/>
            <Environment>
               <Source value="Church"/>
               <Brightness value="1"/>
               <Saturation value="1"/>
               <Rotation value="0"/>
               <RotationAxis x="0" y="0" z="0"/>
            </Environment>
            <Ambience>
               <AmbientLight red="0" green="0" blue="0"/>
               <Shadowing value="0"/>
               <CurrentOcclusionSettings>
                  <RayDirections value="4"/>
                  <TraceDistance value="0.20000000000000001"/>
                  <RayJittering value="true"/>
                  <RayBounce value="true"/>
                  <AvoidStreaks value="true"/>
                  <DirectSamples value="0"/>
                  <ROQuality value="3"/>
               </CurrentOcclusionSettings>
               <CustomOcclusionSettings>
                  <RayDirections value="16"/>
                  <TraceDistance value="0.29999999999999999"/>
                  <DirectSamples value="1"/>
                  <ROQuality value="10"/>
               </CustomOcclusionSettings>
               <ArtisticSettings>
                  <BlackPoint value="0"/>
                  <Midtones value="0.5"/>
                  <WhitePoint value="1"/>
               </ArtisticSettings>
            </Ambience>
         </Lighting>
      </Result>
      <ColorMapControl id="colormapcontrol 01">
         <Name value-en="Noise"/>
         <ExternalImagesMode value="0"/>
         <HDRMode value="0"/>
         <HorizontalAnchor value="1"/>
         <VerticalAnchor value="1"/>
         <PlacementMode value="0"/>
         <TilingMode value="0"/>
         <Color red="1" green="0.5" blue="0" alpha="1"/>
         <AlphaMode value="1"/>
      </ColorMapControl>
      <ColorMapControl id="colormapcontrol 02">
      </ColorMapControl>
      <MapGroup01 id="mapgroup01 01">
         <groupped_colormapcontrol_01 source="colormapcontrol 02" red="1" green="0.5" blue="0" alpha="1"/>
      </MapGroup01>
      <MapGroup01 id="mapgroup01 02">
         <groupped_colormapcontrol_01 red="1" green="0.5" blue="0" alpha="1"/>
      </MapGroup01>
   </Components>
   <GroupNames>
      <Group id="mapgroup01 01">
         <Components>
            <Component name="colormapcontrol 03" group_id="groupped_colormapcontrol_01"/>
            <Component name="mapgroupresult 01" group_id="groupped_mapgroupresult_01"/>
            <Component name="scriptcurve01 01" group_id="groupped_scriptcurve01_01"/>
            <Component name="stones2 01" group_id="groupped_stones2_01"/>
         </Components>
      </Group>
      <Group id="mapgroup01 02">
         <Components>
            <Component name="colormapcontrol 04" group_id="groupped_colormapcontrol_01"/>
            <Component name="mapgroupresult 02" group_id="groupped_mapgroupresult_01"/>
            <Component name="scriptcurve02 01" group_id="groupped_scriptcurve01_01"/>
            <Component name="stones2 02" group_id="groupped_stones2_01"/>
         </Components>
      </Group>
   </GroupNames>
   <Groups>
      <Group id="MapGroup01">
         <Components>
            <MapGroupResult id="groupped_mapgroupresult_01">
               <Source source="groupped_stones2_01"/>
            </MapGroupResult>
            <Sc riptCurve01 id="groupped_scriptcurve01_01">
               <Sc ript value=""/>
               <Settings>
                  <Sizable value="false"/>
                  <Randomizable value="false"/>
                  <SafeScript value="true"/>
               </Settings>
            </ScriptCurve01>
            <ColorMapControl id="groupped_colormapcontrol_01">
            </ColorMapControl>
            <Stones2 id="groupped_stones2_01">
               <Noise source="groupped_colormapcontrol_01" red="1" green="1" blue="1" alpha="1"/>
               <Background red="0" green="0" blue="0" alpha="1"/>
               <Roughness value="0.20000000000000001"/>
               <Contrast value="0"/>
               <Fo rmula value="0"/>
               <Scale value="2.3999999999999999"/>
               <Stretch value="0"/>
               <VerticalStretch value="false"/>
               <Flat value="false"/>
               <SolidFill value="false"/>
               <Details value="0.40000000000000002"/>
               <Variation value="1"/>
               <OctaveCurve source="groupped_scriptcurve01_01" value="0"/>
            </Stones2>
         </Components>
      </Group>
   </Groups>
   <FilterEditor>
      <Groups>
            <Item id="groupped_colormapcontrol_01">
               <Position left="1904" top="-592"/>
            </Item>
            <Item id="groupped_mapgroupresult_01">
               <Position left="1416" top="-528"/>
            </Item>
            <Item id="groupped_scriptcurve01_01">
               <Position left="1936" top="-464"/>
            </Item>
            <Item id="groupped_stones2_01">
               <Position left="1656" top="-592"/>
            </Item>
         </Group>
      </Groups>
      <ThumbnailSize value="1"/>
      <Canvas left="985" top="-1002" zoom_factor="0"/>
      <Viewport left="35" top="21" zoom_factor="1"/>
      <LockPreview>
         <Locked value="false"/>
         <LockedComponent name=""/>
      </LockPreview>
      <Item id="colormapcontrol 01">
         <Position left="1896" top="-592"/>
      </Item>
      <Item id="colormapcontrol 02">
      </Item>
      <Item id="mapgroup01 01">
         <Position left="1728" top="-528"/>
      </Item>
      <Item id="mapgroup01 02">
         <Position left="1440" top="-384"/>
      </Item>
      <Item id="result">
         <Position left="1344" top="-544"/>
      </Item>
   </FilterEditor>
</Filter>
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x00000053 0x001F0001) for window 00A9044A/00A9044A, control: <class Controls::FilterEditor>@03F6CB40.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x00003A68 0x000B0254) for window 0049061C/0049061C, control: <class Controls::Panel>@015AC4C8.
Critical exception occured at thread 00000028 'Application':
<class XFW::Exception> Application encountered an unrecoverable critical error and will be terminated.
Critical exception call location:
<unknown file>(0) : <unknown function>()+0 at 00894FA1 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A87C27 in Filter Forge x86.exe
<unknown file>(0) : LdrGetFailureData()+513 at 77D9F6AF in C:\Windows\SYSTEM32\ntdll.dll
<unknown file>(0) : KiUserApcDispatcher()+110 at 77D42E86 in C:\Windows\SYSTEM32\ntdll.dll
<unknown file>(0) : RtlRaiseStatus()+134 at 77D430C3 in C:\Windows\SYSTEM32\ntdll.dll
<unknown file>(0) : KiUserExceptionDispatcher()+15 at 77D42F2B in C:\Windows\SYSTEM32\ntdll.dll
<unknown file>(0) : <unknown function>()+0 at 00A80E16 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006B61CA in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006B1E27 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00409E7B in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006B985F in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006B4820 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006B484E in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006A579A in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0072B36E in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00769615 in Filter Forge x86.exe
Reproduced. Thank you, one more bug point.
119 unregistered users.
