Steps to reproduce:
1. Create a new filter.
2. Create a Perlin Noise.
3. Create an IntSlider.
4. Connect the IntSlider to the Variation of the Perlin Noise.
5. Set the IntSlider's max Value to 1000.
6. Change the IntSlider's Value.
7. Select both components and group them.
8. Copy and paste the group.
9. CRASH!
Operating system: x64 Edition (6.1 build 7601) Service Pack 1
Physical memory: 3766 MB
Number of processors: 4, available: 4
Processor info: Intel® Core™ i5 CPU M 480 @ 2.67GHz, ~2636 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [15.09.2012 13:33:46 Mitteleuropäische Sommerzeit]
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x00000056 0x002F0001) for window 0008036E/0008036E, control: <class Controls::PushButton>@044767C0.
Exception reported at thread 00000FC0 'RenderingMgr 04292100':
<class XFW::StateError> The root component is not initialized for the group 'mapgroup01 02'
Possible original exception location:
<unknown file>(0) : <unknown function>()+0 at 006BCAE0 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006DA2C1 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006F764E in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00898D87 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00893E80 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006F3289 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0088D437 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00889CB0 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:7648B9BC, SS:ESP 002B:0A02EE74, EBP 0A02EEC4, FLAGS 00000216
CONTEXT_INTEGER: EAX 0A02EE74, EBX 00000000, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 0A02EF04
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x0000004E 0x00310001) for window 000603D4/000603D4, control: <class Controls::PushButton>@04659960.
Exception caught at thread 00000E94 'Application':
<class XFW::ArgumentError> Control value 710 is out of control range [1, 20] in control 'intslidercontrol 02'.
<unknown file>(0) : <unknown function>()+0 at 0078773B in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0041D195 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006BA6CA in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 08B1B778 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:7648B9BC, SS:ESP 002B:00187570, EBP 001875C0, FLAGS 00000212
CONTEXT_INTEGER: EAX 00187570, EBX 08DAF5D8, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 00187600
On a tangent:
When inside a Group, an IntSlider's Max Value is suddenly called Value Range and limited to a maximum value of 20, but outside the Group the Max Value can go up to 1000!
Ok, the culprit appears to be the IntSlider:
2. Create an IntSlider.
3. Set the IntSlider's max Value to 1000.
4. Change the IntSlider's Value to >20.
5. Select the IntSlider and group it
6. Copy and paste the group.
7. CRASH!
Processor info: Intel® Core™ i5 CPU M 480 @ 2.67GHz, ~2647 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [15.09.2012 15:20:56 Mitteleuropäische Sommerzeit]
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x00000056 0x002F0001) for window 00230532/00230532, control: <class Controls::Panel>@046C15A0.
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x0000004E 0x00310001) for window 0046049C/0046049C, control: <class Controls::PushButton>@0033C2C8.
Exception caught at thread 00000F88 'Application':
<class XFW::ArgumentError> Control value 740 is out of control range [1, 20] in control 'intslidercontrol 02'.
<unknown file>(0) : <unknown function>()+0 at 001874B4 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00C8CEA8 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00C07580 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0675D898 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0675EA70 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 001874B0 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 001874FC in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A9A730 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0078632E in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:7648B9BC, SS:ESP 002B:001873F8, EBP 00187448, FLAGS 00200212
CONTEXT_INTEGER: EAX 001873F8, EBX 08CEF060, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 00187488
Alternatively:
4. Select the IntSlider and group it.
5. Copy and paste the group.
6. Select both groups and delete them.
7. CRASH!
Processor info: Intel® Core™ i5 CPU M 480 @ 2.67GHz, ~2641 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [15.09.2012 15:26:10 Mitteleuropäische Sommerzeit]
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x0000002E 0x01530001) for window 00230542/00230542, control: <class Controls::FilterEditor>@088880E8.
[Controls::Control] Exception occured while processing window message 0x00000100(WM_KEYDOWN) (0x0000004E 0x00310001) for window 000B02D0/000B02D0, control: <class Controls::PushButton>@02F4FC08.
Exception caught at thread 000000C0 'Application':
<class XFW::ArgumentError> Value (1000) is out of range [3, 20] for property 'ValueRange'.
<unknown file>(0) : <unknown function>()+0 at 006C72FB in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00763399 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00418897 in Filter Forge x86.exe
<unknown file>(0) : Ordinal234()+299634 at 748904EE in C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
<unknown file>(0) : <unknown function>()+0 at 0047454C in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00418EAC in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 04C48308 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 04478B00 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 085F8904 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00418E2C in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00B230D4 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:7648B9BC, SS:ESP 002B:00184474, EBP 001844C4, FLAGS 00200216
CONTEXT_INTEGER: EAX 00184474, EBX 00184C48, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 00184504
Sharandra
Filter Forge Addict
Here is another way to produce the same error:
1. Create a switch
2. connect an intslider
3. create a group
4. Connect an intslider
5. Check remapping and set offset to 2
6. Set value to max (not max value, the normal value)
7. Crash
Looks very similar to the other Inslider issue already reported.
138 unregistered users.
