Bionic
Curve Script:
You will have a locked Integer Slider control inserting a max value exceeding 10000.
Example: set value to 100000 and this will result in a locked Integer Slider control.
Minimum value gives a warning of actual thresholds levels which you may and may not use which is correct.
Feature is there but just not for maximum thresholds levels resulting in a locked slider control exceeding value of 10000.
It should be like this:
Perhaps crazy big value to add for a slider smile:D but something is missing & something got stuck. smile:!:
Bionic
Offtopic:
All letters are not allowed [ÅÄÖ]
Bionic
Map Script: (similar behaviour)
If you set Integer Slider value to 1000000 it's adjustable up to 16960
If you set value to 100000 Integer Slider control is locked
The testers would prefer to hold this one until the Intslider logic bug is fixed. If the issue persists after we release the bugfix, please bump this thread.
Offtopic: I suppose we should write 'Latin letters' instaed.
Bionic
Bump Windows platform
[MAC] 4.002.27586 # Curve Script/Integer Slider
Also there on MAC, add 6 numericals, adjust slider and there's imminent crash on MAC platform.
63 unregistered users.
