Bionic
Reproduce:
Curve script -> New input -> Curve Inputs -> Set some name -> Select Required input -> press OK
Code
Operating system:  x64 Edition (6.2 build 9200)
Physical memory: 8068 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7-3770K CPU @ 3.50GHz, ~3476 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [2012-09-14 18:19:16 W. Europe Daylight Time]
[Controls::Control] Exception occured while processing window message 0x00000201(WM_LBUTTONDOWN) (0x00000001 0x000C0055) for window 00BE073C/00BE073C, control: <class Controls::Label>@0796A108.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x00000CC8 0x0228077C) for window 013704E2/013704E2, control: <class Controls::Panel>@0445DCA0.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x000B0027) for window 0228077C/0228077C, control: <class Controls::PushButton>@03D20CC8.
Exception caught at thread 00000D8C 'Application':
<class XFW::RuntimeError> Cannot set unsigned value for required connection point 'TEST', component ''(<class FFXLib::ScriptCurve>@03F048E8).
<unknown file>(0) : <unknown function>()+0 at 007766D3 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0040A238 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:75634B32, SS:ESP 002B:001845A8, EBP 00184604, FLAGS 00200212
CONTEXT_INTEGER: EAX 001845A8, EBX 001846B0, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 00184644
Bionic
This happens also with Map Script
Both reports of Curve Script and Map Script were submitted
Code
Processor info: Intel® Core™ i7-3770K CPU @ 3.50GHz, ~3486 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [2012-09-15 01:08:16 W. Europe Daylight Time]
[Controls::Control] Exception occured while processing window message 0x00000201(WM_LBUTTONDOWN) (0x00000001 0x0012005E) for window 01BF0A26/01BF0A26, control: <class Controls::Label>@0F04D070.
[Controls::Control] Exception occured while processing window message 0x00000111(WM_COMMAND) (0x000056B0 0x00B6079C) for window 00DB0B40/00DB0B40, control: <class Controls::Panel>@044C3C70.
[Controls::Control] Exception occured while processing window message 0x00000202(WM_LBUTTONUP) (0x00000000 0x000E0024) for window 00B6079C/00B6079C, control: <class Controls::PushButton>@03E456B0.
Exception caught at thread 00000D14 'Application':
<class XFW::RuntimeError> Cannot set unsigned value for required connection point 'TEST', component ''(<class FFXLib::ScriptMap>@09D88350).
Thanks! Reproduced and already fixed, a bug point for you.
Bionic
This bug is re-introduced in build 4.2.27587
Reproduce:
I submitted just one report so you're aware of it.
[ Filter Forge x86 Bug Report.txt ]
Bionic, thanks for checking! I think this is another bug point as the previous bug was clearly marked as fixed.
43 unregistered users.
