Sharandra
I grouped a lot of components and then grouped these and at some point it crashes. It is reproducable, will attach the filter part.
I get this error message: <class XFW::ArgumentError> Range for unsigned connection point with 2 values or less aren't good idea. Use list or checkbox instead. Bug report submitted
group crash.ffxml |
| Posted: September 14, 2012 8:36 am | ||||
Posts: 3507 |
Looks very similar to this one.
| Posted: September 14, 2012 8:43 am | ||||
Sharandra
If you group all these components it will crash.
And there is also the issue that incoming connections of other parts of the filter are being replaced by color components after ungrouping, as I reported before. |
| Posted: September 14, 2012 8:45 am | ||||
Sharandra
Maybe, I didn´t copy paste tho. Just grouped them. I´ll see if I can find out what part exactly causes the crash. Edit: It seems to be the first switch. Can´t group the stuff before that because of too many outgoing connections, if you include the switch it crashes. Edit 2: It also crashes if you duplicate the first group and then try grouping with the switch. |
| Posted: September 14, 2012 8:46 am | ||||
Sharandra
The crash is caused because of the switch demanding a checkbox instead of an int slider with only 2 choices available.
| Posted: September 14, 2012 11:12 am | ||||
Posts: 3507 |
The testers would prefer to hold this one until the Intslider logic bug is fixed. If the issue persists after we release the bugfix, please bump this thread.
| Posted: October 3, 2012 9:07 am | ||||
Sharandra
No bug point? *sad puppy face*
| Posted: December 19, 2013 8:17 am | ||||
Posts: 3507 |
Sorry Sharandra, but SpaceRay was the first to report this issue. Your post is just another manifestation of the same bug where the IntSlider logic was completely broken.
| Posted: December 19, 2013 9:24 am | ||||
Sharandra
Why did they both get a point for two manifestations of the broken intSlider logic and I don´t get one for a third?
Edit: Sorry for being a pain, and I don´t want anyones bug points taken away, just trying to understand your logic |
| Posted: December 19, 2013 9:36 am | ||||
Posts: 3507 |
Not willing to dig into the details of the long-fixed issue...
On a second thought, I don't want to look greedy about bug points. Let it be equality for everyone, and another bug point for Sharandra. |
| Posted: December 19, 2013 10:31 am | ||||
Sharandra
Thank you!
| Posted: December 19, 2013 10:39 am | ||||
19 unregistered users.
