Bionic
This causes a flow of exception errors.
Submitted via built-in bug reporting tool.
Code
Operating system:  x64 Edition (6.2 build 9200)
Physical memory: 8068 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7-3770K CPU @ 3.50GHz, ~3476 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [2012-09-13 20:20:20 W. Europe Daylight Time]
[Controls::Control] Exception occured while processing window message 0x00000114(WM_HSCROLL) (0x00020005 0x005C05B4) for window 00B709B2/00B709B2, control: <class Controls::ValueControl>@093A68D0.
[Controls::Control] Exception occured while processing window message 0x00000200(WM_MOUSEMOVE) (0x00000001 0x000B0009) for window 005C05B4/005C05B4, control: <class Controls::TrackBar>@093A6AC0.
Exception caught at thread 000005CC 'Application':
<class XFW::ArgumentError> Range for unsigned connection point with 2 values or less aren't good idea. Use list or checkbox instead.
<unknown file>(0) : <unknown function>()+0 at 007611FB in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00765A11 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:75634B32, SS:ESP 002B:00180698, EBP 001806F0, FLAGS 00200212
CONTEXT_INTEGER: EAX 00180698, EBX 00180A64, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 00180730
Code
Processor info: Intel® Core™ i7-3770K CPU @ 3.50GHz, ~3460 MHz
Critical exception occured at thread 000005CC 'Application':
<class XFW::Exception> Destructor for object <class FFXLib::ComponentManager>@04C0DC30 failed.
Critical exception call location:
<unknown file>(0) : <unknown function>()+0 at 008911A9 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00891151 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006D29C0 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 0088D437 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00474505 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00474608 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006D6B01 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006F20A0 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 006F20C8 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00476281 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A87BD7 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A873CB in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A87B4C in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00A809C7 in Filter Forge x86.exe
<unknown file>(0) : RtlRaiseStatus()+180 at 774E30F1 in C:\Windows\SYSTEM32\ntdll.dll
<unknown file>(0) : RtlRaiseStatus()+134 at 774E30C3 in C:\Windows\SYSTEM32\ntdll.dll
Possible original exception location:
Thanks for reporting. Yesterday reports by SpaceRay and CFandM have already clarified the problem with IntSlider logic.
138 unregistered users.
