Sharandra
Filter Forge Addict
Not sure if it´s a bug or intended. I had an int slider inside a group, max value set to 4. Now outside thegroup I connected another int slider. Before saving it correctly gave only 4 choices. After saving it had 12. Solution was to also limit it´s max range to 4. Shouldn´t the controls respect the control limits inside a group?
Thanks for reporting. There is a problem with Inslider logic outlined here.
