I'm on a Mac 10.7.4 here with 2.66GHz Corei7 laptop.
Steps:
1. Create a group
2. Pan around inside the group.
Description: Typically panning around in the filter editor itself is pretty ok speed, but when panning inside a grouped component it has some lag and the frame rate for panning is significantly lower.
Is the group big? Can you post the filter?
We can reproduce a noticeable lag. I guess it's a bug point for Skybase.
It happens with everything I do. Even after it's done rendering it has issues. I made a quick nothing special filter which will hopefully demo the problem....
[Edit] Posted without reload. Saw the new message Yay!
Try Panning in Group.ffxml
59 unregistered users.
