Bionic
Submitted via built-in bug reporting tool.
Windows 8 RTM x64/ CS6 x64
Techno -> Metal panels -> Apply
Code
Operating system:  x64 Edition (6.2 build 9200)
Physical memory: 8068 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7-3770K CPU @ 3.50GHz, ~3476 MHz
Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [2012-09-12 19:49:25 W. Europe Daylight Time]
Exception reported at thread 00000C50 'FetchingMgr 051D5D58':
<class XFW::OSCallError> ::WriteFile(block 4, parent pipe 00000A8C, slave pipe 014ADBD8) failed with error code 0x000000E8: The pipe is being closed.
Possible original exception location:
<unknown file>(0) : <unknown function>()+0 at 00887BBF in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 088DF020 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00C8CDE4 in Filter Forge x86.exe
<unknown file>(0) : <unknown function>()+0 at 00BDE7A0 in Filter Forge x86.exe
CONTEXT_CONTROL: CS:EIP 0023:774F4B32, SS:ESP 002B:088DEF10, EBP 088DEF68, FLAGS 00000212
CONTEXT_INTEGER: EAX 088DEF10, EBX 088DF2E4, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 088DEFA8
Exception caught at thread 00000438 'Application':
Bionic, all kinds of pipe errors (you can come across a 'broken pipe' as well) are caused by the host application, not by Filter Forge. It is the host app that terminates the communication between itself and the plugin.
