cgbeige
I can't use the filter editor - it just crashes the app in Lion.
cgbeige
also, the Photoshop plug-in just crashes Photoshop.
What Photoshop version do you use?
xirja
Idididoll Forcabbage
I too have multiple crashes in the filter editor in stand alone mode OS 10.6. It seems that if certain sliders of components are changed or text in name field, a crash will occur. Disconnect the Result component and the crashes stop. Make the connection to the Result component the last edit, and you should be good, for the mean time.
cgbeige
I'm using Photoshop CS5 64-bit and CS6 64-bit beta - I'm an official beta tester so it's later than the one that leaked.
I'll try the result toggle - thanks
Do you have CS5, 5.1 or 5.5?
Please send the full error message and the automatic error report if any.
Also, don't expect support for CS6 until it is commercially available.
cgbeige
CS5.1 - they're both the same I think, at least from a feature standpoint.
cgbeige
here's the crash log
[ crashlog.txt ]
b15fliptop
Filters: 3
Getting very frequent crashes in Standalone mode in Lion when using the filter editor.
cgbeige
ya, any word on a fix for this?
b15fliptop
Filters: 3
In fact, I'm trying to add a "Set Alpha" component to a filter now, and every time I try to set the color in "Source" it crashes.
Every.
Single.
Time.
smile:evil:
b15fliptop, please send the filter that causes the crash or attach it here.
b15fliptop
Filters: 3
Here ya go.
New Sketcher.ffxml
b15fliptop, thank you very much. We've reproduced the Set Alpha issue.
BLUEFROG
Filters: 6
Just an FYI - I've got the same SetAlpha crash in standalone with FF 3.006 on OS X 10.6.8.
cgbeige
any chance this will be fixed? An update would be nice.
cgbeige, this will surely be fixed in the next program update.
cgbeige
great - thanks
We've released a hotfix without incrementing the program version that should eliminate the issue (as well as another issue with naming controls). Please redownload and reinstall from our download page if you experience this crash.
cgbeige
great - seems not to crash but now I've found a weird bug where the sliders disappear. See video:
http://dl.dropbox.com/u/7990437/disap...rforge.mov
Thanks cgbeige! That's what I call a good feedback from users — a video is worth more than a thousand words smile:) We've reproduced the issue, please wait for the next program update.
