Mike17
Hi ,
I don't know if this is the right place to mention this.
I had a problem while installing filters to my library. Suddenly Filter Forge crashed, and when trying to restart it, it just appeared for a second and then closed again. After deleting my library to a fresh start, Filter Forge worked again.
So i went through building up my library again by installing the filters, and making a backup of the library every several pages of filters until i reached the point again where Filter Forge crashed and wouldn't start up again.
I tracked the problem down to this filter:
http://www.filterforge.com/filters/8562.html
Installing that filter crashed my library. I don't know if it is a filter problem with the mac version ?
But i just wanted to mention that here. Maybe there is even a better solution to repair the library , then the way i did. But now i am glad i found the culprit.
I just hope that there aren't anymore filters that crash my library.
Cheers
Mike
Mike, please email the support team with this issue.
29 unregistered users.
