Jason Hamilton
Hey, I was having a problem with my FF where it would crash whenever I ran it, one of you guys suggested to try installing it on a different account(I created a new one to see if it would work), and it worked, but when I run the same program on my original account it has the same problem, any idea on how to fix this?
I guess the issue is related to file/folder permissions. I'm afraid I cannot give specific advice but if you set identical permissions for both accounts Filter Forge should run fine.
Jason Hamilton
I changed all permissions in the information panel (cmd + i)of the filter forge 2 folder to read and write for all, but it still doesn't work, any other ideas?
Jason Hamilton
would it help if I sent you guys my crash report?
Is it an MacOs crash report or a Filter Forge one (created on clicking the 'Generate bug report' button)?
Jason Hamilton
Mac OS report, the kind that get sent to apple, I know that raaj was having a similar problem but he was getting a FF crash report.
Jason, unfortunately the MacOs report is of little use in this case. Is it possible you just migrate to the new account where everything works?
24 unregistered users.
