Sam Jones
Working in CS4 last night on a file. I attempted to download a new filter and was prompted to update first. After installing the update, CS4 is slow on all operations and freezes when attempting to go to FF. I am on a MAC 10.5.8 and pro version of filterforge.
Sam, does your problem look like Ellie's one?
Sam Jones
The problem is similar but I am using the pro version
Sam Jones
Just tried the same thing on a very small file and CS4l is frozen. So other than that it seems to be similar to Ellie's predicament
Sam Jones
More info: Created a file 300 x 240 as a test per Ellie's problem. After approx 2 min waiting i was able to apply filter effects but system is slow and boggy!?
Denny
Human
I am having the same problem,
tps_wave
I'm using CS2 with the standard edition, and after the update the following problem occurs. In photoshop (using images less than 1000 x 1000), I go to FF and then the wait starts spinning and FF appears below PS and does not move to the top window. I have to sel ect FF fr om below to bring it to the top. It takes longer for the filter to load then the previous version. Another thing that is strange is after I apply the filter when I return to PS it doesn't update with the filter result, even after FF is finished processing it. I have to resize the PS window to get the image to update with the filter applied.
I'm on a Macbook Pro with 10.6.5.
19 unregistered users.
