Raaj
Hi,
Just purchased and installed FF on my Mac this evening running OS X 10.6.5.
FF Crashes immediately on doubleclicking the standalone app with the following msg in a window:
"<XFW::CarbonCallError> SendEventToEventTarget(event class '(kEventClassAppleEvent, kEventAppleEvent)'). failed with os status errAEPrivilegeError / telBadHandErr(-10004): / bad handle specified ."
The window has a button "Generate Bug Report" but clicking it makes the whole window go away.
Exact same behavior when opening FF from Photoshop CS4.
I did completely remove and reinstall a couple of time, no effect - exact same behavior. Nothing seems to be getting logged to the Crash Logs or Console.
Help!
Thanks,
-raaj
[Mod update: People seem to find this page in Google, so TLDR: check if you have Simbl/EasySimbl installed. It is known to block Filter Forge from running properly. ]
Thanks for reporting, we'll look into it.
Raaj
After doing yet another delete and install, with the same results - immediate crash on execution, I noticed that the "Filter Forge 2" directory in /Applications has permissions that look interesting:
_unknown: Read & Write
wheel: Read only
everyone: Read only.
Is this correct?
Also, in the "Filter Forge 2" directory, the executable Filter Forge.app has permission of:
system: Read & Write
admin: Read & Write
I'm still dead in the water...
Thanks for your help. Hopefully you guys have found the issue.
Raaj
Upgraded to 10.6.6 today. Exact same behavior - dies on invoking with the following message:
Any pointers?
Thanks!
Victoria Kostyukova
Raaj, I responded to your email -- please check your mail.
Raaj
Hi Victoria,
Per your instructions I changed the owner recursively (chown -R) for the FIlter Forge 2 directory in /Applications to me and made sure I had Read+Write privileges. I also verified that the /Users/My_User/Library/Application Support/Filter Forge 2 folder had access rights of Read + Write for my user.
Exactly same error:
Thanks for your help. Hopefully we can get this fixed - I'm still dead in the water!
Cheers,
-raaj
Raaj, we'll reply you by email as soon as the developers look into the issue.
Raaj
Thanks, GMM. Hopefully you guys will have something for me soon. Appreciate your help as I'm dead in the water.
Raaj
Downloaded the latest today and exactly same issue...
bleating
I'm having the same problem with freshly downloaded FF2. Using OS 10.6.5 smile:(
Raaj and bleating: how many filters do you have in your Filter Forge?
Raaj
GMM - this install was the first time install (after purchase) so I'm not sure how to answer your question. I guess the number of filters would be whatever the original install puts in there. Since FF has never worked for me, I haven't downloaded any additional filters.
I would really like you guys to fix this - it's not often that one purchases SW that simply does not work on your machine.
Please fix!
Thanks,
-raaj
Raaj
BTW, Since FF crashes immediately upon starting, I'm not sure I could even be able to tell you how many filters I have, unless there's some place to go look in the Mac Filesystem.
Please try to remove or rename the ~/Library/Application Support/Filter Forge 2/ directory and run FF again.
Raaj
Removal of that directory did not appear to do anything. Invoking FF caused a window with "Internal Error" on the Window title to appear with the follow message:
The window also has a button that says "Generate Bug Report" - clicking that makes the window go away and nothing else happens.
In other words, exactly the same as before.
Raaj
Invoking FF from Photoshop CS4 results in a window that says - "Could not complete the Filter Forge 2 command because of a problem with the filter module interface" Then the window I documented earlier appears outside of PS. I've attached an image of the FF error window.
Does that help the debugging effort?
Cerridwen
I am getting same issue prompt stating that could not complete FF# command due to filter module interface
Rhinoboy1972
Rhinoboy1972
getting same problem...this is killing me! send me a refund! the app is broken....or moderator, please prescribe the fix!!!!!! costing me real time & $$$$$$$$$$$$$$$$.
Rhinoboy1972, please check if you have set full permissions for the Filter Forge folder. Or you can use Filter Forge as a standalone app.
bilbaggins
bilbaggins
I've been having this same issue for some time now with no help from app owners/developers.
Please advise how to resolve the crashing in OSX 10.6.
This is a useless app if it won't run.
Please do something!!!
KISS
Unhappy former user
They're never going to help you. I've been having the same problem with OS 10.7. It worked fine before I upgraded about a year ago. I've tried to get help via Support and have tried the various suggestions on the forums. Support is generally non-responsive. Nothing works. It just crashes. It won't work with Photoshop. It won't work as a standalone. It will open as a standalone, but I can't even download any filters at this point--it just tells me I don't have FF, even when I go via the "download filters" link in FF and I'm logged into the site. I have tried reinstalling, numerous times. Whether with Photoshop or as a standalone, the program is completely useless. You wasted your money. And now they have the gall to email trying to get us to upgrade to FF 4! It's a shame, because it worked well with OS 10.5, at least on my old system. I used to use Filter Forge constantly before I upgraded my Mac. I'm angry over all the futile time I've lost trying to get this to work.
(And, yes, I have full permissions set...etc.)
TheAlikA
The AlikA
Same here:
Downloaded FF3 then upgraded to FF4 Beta and now I get an error:
I Deleted all file Data, tried placing FF in User Aplications folder - no luck
OS 10.8.2 FF4 Beta
Error on standalone
error onPhotoshop CS5.0
Splash screen image that I managed to capture just before it gives me the error.
as it goes : Still in Dead Water
www.thealika.com
TheAlikA, how many filters (approximately) do you have in the local filter storage? Dozens, hundreds or thousands?
TheAlikA
The AlikA
Hey GMM I have only the original presets that came with FF.
I will be happy to trace down the error with you and find the root if you would like to try.
www.thealika.com
TheAlikA, please make sure you've got full permissions for the /Applications/Filter Forge 4/ folder.
TheAlikA
The AlikA
GMM Thanks for your advice, I tried that but to no avail....
I must say that I have read through the forum and tried everything suggested here already.
if you have a list of things I could try - I could implement them one by one...
www.thealika.com
TheAlika, please try to remove the /Users/Username/Library/Application Support/Filter Forge 4/ folder, then redownload and reinstall FF 4.
TheAlikA
The AlikA
Thanks, GMM Tried that, Deleted all data related to Filter Forge in the Library/Application Support folder
then re-installed the FF 4.002 same error :\
I also uninstalled using "CleanMyMac" which is supposed to remove all extra files related to FF.
www.thealika.com
I know such things are uncommon on Macs, but do you by chance have an antivirus or a debugger running?
TheAlikA
The AlikA
ok I got it!
I opened "Activity Monitor" and shut down one service at a time.. the problem in my case is: SIMBL Agent...
can be found here: http://www.macupdate.com/app/mac/18351/simbl
Seems to be fine after i quit it (I now Uninstalled it)
I got SIMBL with an app called Side Effects http://www.macupdate.com/app/mac/43078/sideeffects
p.s. will this count as a bug for the Beta Test Program?
I'm Looking forward to use and help out with your amazing software...
these are the kind of effects I am planning to produce: http://www.behance.net/gallery/Picass...gh/4415311
All the Best.
Nikita @ TheAlikA
www.thealika.com
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
17 unregistered users.
