pafonk
Hello,
I started to use Filter Forge 2 since yesterday and have a annoying problem with my left mouse button after using the package for about 10 minutes. It simply stops responding, the only workaround I have found so far is rebooting my MAC with some help of the keyboard. It seems to happen if I'm using the application (change for example some texture color) while the last texture render is not yet finished. it also feels like this is always happen at high CPU load. I'm working with Snow Leopard and do not experiencing this problem with any other application on my machine.
Peter.
Totte
Ubernerd
Filters: 107
Been using FF in 10.6 for a year and haven't experienced that problem. Are you sure the mouse button dies, not a Dialog (Color Seletor Dialog) is still visible and is Modal?
pafonk
Totte,
I can work for countless hours without any problem. 10 minutes FilterForge and my left mouse button stops responding. I also had it a few times just hanging on a filter slider. Killing the Filter Forge application at that point does not make any difference for my left mouse click. only a reboot will make it work again. I noticed that the problem stays away if I start Filter Forge from Photoshop. It only seems to occur with the stand alone application. smile:!: I'm using an one month old Wacom intus 4 L tablet in combination with the additional Wacom mouse. I also installed a month ago the latest drivers for this device. As told before the tablet works perfect with any other application on my MAC (Photoshop, Maya, 3d Coat.....).
Thanks for your reply. smile:D
Peter.
12 unregistered users.
