carolsvec
I switched to 32 bit, I dragged the FF folder to the PS/filters folder. I get a "program error" every time I try to launch FF. What else can I do? I getting ready to revert to CS4 for all the difficulties I'm having with FF and just about every other plug-in I have.
FF isnt a filter; it's a plugin. try putting it in the plugins folder.
carolsvec
I have more info. I was mistaken with the folder initially--it was in the plugins folder. I was messing around with it and discovered that FF only works for me if I reduce the size of my image significantly--for me, it seems like under 25% of the original will open FF, otherwise it tells me that there is a program error.
FYI, one of the last times, it generated a BUG report that was sent to FF.
gholmes1936
GunnerHolmes
Kraellin, it would seem like the FF app. would work as a stand alone app. on a Mac/PC. No?
gunnerholmes
gholmes
Austin, Texas
as far as i know it shld, gunny. other mac users seem to be using it ok. but see the other threads on this. i dont have a mac and my cs5 isnt installed yet. i'm still using cs3, when i use it.
Robin Wood
Filters: 4
csvec, FF isn't supported yet in CS5. There is a workaround that might help you.
carolsvec
Sorry, should have closed this. It's working fine. I forget how I fixed it. sorry for the extra confusion.
