Dissenyirauxa
Hi,
there are two little bugs in FF 1.017 for non english languages.
1) When I edit Filter Info I can not write any accent or other diacritical sign. Edit Filter Info stops and I must exit and re-enter to continue writing.
2) In localized versions of Photoshop (like spanish), there are not the "Plug-Ins" folder. Her name is "Plugins". Therefore, the install script do not runs properly. Now the solution is to create a new folder named "Plug-Ins" and to make a new install. Then, in PS preferences the folder "Plug-Ins" must be the second plugins folder.
Dissenyirauxa,
1. I assume you're using the Mac version? It fails to operate properly when you type accented symbols in the Authors URL field. However, valid URLs don't contain diacritic letters. Are you experiencing this or something else?
2. Thanks for reporting, we're aware of the fact and will surely do something about this when time permits.
Dissenyirauxa
GMM,
1) Sorry. Yes, I use Mac version (OSX 10.4.11). It fails to operate properly with accents in ALL fields. Of course, in some fields (like URL) that is not important, but in other fields (Author Name or Filter Description) I think that this behaviour is at least uncomfortable. For instance, my name is Néstor Macià, but not Nestor Macia:)
2) OK, thanks.
Dissenyirauxa, we're unable to reproduce the accent problem. How do you you enter these symbols - by copy-pasting or via keyboard?
Dissenyirauxa
GMM,
I try enter these symbols via keyboard.
When I can, I will try to reproduce the accent problem with another computer and I will explain you the result.
Totte
Ubernerd
Filters: 107
I did report this months ago.
On my Swedish" Keyboard, ' is next to the [Return]-key, and typing ' in any textfield in FilterForge (1 or 2) will cause edit sheet to hang and you need to close and reopen.
12 unregistered users.
