ohnaka
running filter forge corrupts solid color in areas the filter is not being run on. When using the magic wand tool in photoshop set to zero you will see single pixels that were changed.
Running 10.5.6 macbook pro Intel Core 2 Duo 2.6 GHz with 4gb ram.
If a filter uses the Selection component, Filter Forge assumes that the filter needs to modify pixels outside the selection. In this case, Filter Forge does not mask the filter output with the selection – the filter output simply overwrites the original image ignoring the selection.
17 unregistered users.
