Daniel Sroka
Posts: 20 |
I tried installing 1.016 from within the Filter Forge app. Everything went as it should, but when I tried to run the standalone application, I got the error:
I downloaded the installation manually, and re-ran it, and got the same problem. Next I'll try deleting the app (so it will install instead of 'upgrade'), and doing a clean install. |
| Posted: March 14, 2009 7:37 pm | ||||
Daniel Sroka
Posts: 20 |
Deleting the app and reinstalling doesn't work: I still get the same message.
Posts: 3507 |
dansroka, please report your Mac OS version. A screenshot of the error message would be helpful as well.
| Posted: March 16, 2009 7:33 am | ||||
Daniel Sroka
Posts: 20 |
| Posted: March 16, 2009 11:14 am | ||||
Posts: 3507 |
Thank you, dansroka. The credit for the bug goes to you.
All user settings are stored in '/Users/UserName/Library/Application Support/Filter Forge'. |
| Posted: March 17, 2009 6:08 am | ||||
Daniel Sroka
Posts: 20 |
Thanks.
I just tried deleting the app be deleting these folders: - Applications/Filter Forge/ - /Users/UserName/Library/Application Support/Filter Forge And then reinstalling the app. The installer still only have me the option to 'Upgrade', and when I did, I got the same error as above. How can I completely uninstall the application? The directory /Library/Receipts/ contains two files named Filter Forge: - filterForge.pkg - filterForgeInstallables.pkg Should i get rid of those to do a clean install? Thanks, Dan |
| Posted: March 17, 2009 9:37 am | ||||
Aluramia
Posts: 1 |
Hi Dansroka and DMM...
I have the same issue. Sniffs...I miss my filter forge. Mac Os X 10.4.11 ~ on Intel Core 2 Duo (Mac side).
Is there a way around this problem?
Thanks If we all are here to help others , then what exactly are others here for? |
| Posted: March 17, 2009 9:43 pm | ||||
Posts: 3507 |
There should be 3 files named Filter Forge there. They notify the installer that Filter Forge is already installed on the machine – so if you want a clean installation you should erase them as well. Unfortunately reinstalling FF will not fix the bug in v. 1.016 that prevents it from running. Please wait for us to release a hotfix for this. |
| Posted: March 18, 2009 6:12 am | ||||
Daniel Sroka
Posts: 20 |
Thanks for working on it. Is there an older version of the beta available online?
| Posted: March 18, 2009 9:33 am | ||||
Posts: 3507 |
We've released the hotfix that eliminates the 'damaged application' issue. Please download it and reinstall using this link: http://www.filterforge.com/download/F...0Setup.dmg
| Posted: March 25, 2009 10:28 am | ||||
Daniel Sroka
Posts: 20 |
Excellent! I have installed the hotfix, and Filter Forge now works again. Thank you!
| Posted: March 25, 2009 11:04 am | ||||
leo
Posts: 1 |
Can I ask why the problem occurred and what was the fix done for the 'damaged application' issue? Thanks.
| Posted: July 15, 2009 5:22 am | ||||
Posts: 3507 |
leo, the fix was for v. 1.016. There were no issues reported with 1.017, you can download it from the download page.
| Posted: July 15, 2009 12:21 pm | ||||
SV Perry, 44 unregistered users.
