mikaelu
The plugin installer don't look for elements. Is there a way for a manual install?
There's an unofficial way: put an entire copy of Filter Forge folder into the Elemnts Plug-ins folder.
mikaelu
A symbolic link also works:
sudo ln -s /Applications/Filter\ Forge/ "Filter Forge"
From the command line, in /Applications/Adobe Photoshop Elements 6/Plug-Ins
This is Unix after all.... smile:)
mikaelu
Addendum:
Works as in: it opens Filter Forge with the correct layer.
The rendering is however extremly slow or not functioning at all (does not update/reopen elements) / Elements hang.
Using ver. 1.015, Leopard on a MacBook Pro.
Well, we don't officially support Elements, after all...
DeboraThom
Debora
I have photoshop elements 2019 and when I go to install the plugin it isn't in the file? How do I get it so I can use it with my elements?
