Was this reported?
After rendering, the cursor does not return to its normal state unless input boxes are pressed. In other words, nothing can be clicked. This seems to also happens *rarely* and I couldn't replicate this after several tries. Although as far as my experience goes, this does happen.
I often run other applications, including Firefox while playing around with Filter Forge. Although I've done clean runs and somehow that happened before as well.
Either way I just wanted to let known, although I cannot guarantee the steps below will always hit it.
I am running the latest MacOS X 10.5.6 I believe and Filter Forge: 1.014.
Steps in replication:
1. Start rendering in filter forge standalone.
2. Render an image.
3. After the render is finished, the hand cursor appears which does absolutely nothing no matter where you press. Such as the setting sliders don't work.
4. To solve this problem I ended up pressing the value boxes (input I should say) to somehow release the mouse from its "hand" state to the regular clickable state.
Note: This does seem to "vanish" after a preview render goes.
The reported behavior may (or may not) be a manifestation of the 'mouse click-through' bug that has been fixed in the latest version 1.015.
Please report if you face this issue in the new version.
15 unregistered users.
