Ravenstia
I have the same issue as the initial thread, I am running Pshp CS2 on an Intell iMac, initially got an "FF application command error" pop-up in CS2 and no response as a stand alone. I tried the trick of putting an entire copy of the FF folder in the plug-ins folder and the only change was the beachball appeared and stayed (no pop-up).
Ravenstia
Igor Lorents
Filter Forge, Inc.
Thanks for reporting this, we'll fix it ASAP.
