The problem I found is attached in FF15..This is the Text Component put through a Scale (.75) to the output. If viewed in Draft mode, the position of the character moves. I've also noticed that the Preview Video and reduced % renders in animation are effected as well.
Text-Scale-Preview.ffxml Math meets art meets psychedelia. |
| Posted: March 13, 2026 12:04 am | ||
Posts: 3507 |
Unfortunately this is a flaw with the Text component. It is somehow related to your latest posts in this forum thread. This is on our to-do list but I'm afraid I can't give an ETA on that.
To repeat, this issue should only occur with the Text component. If you encounter similar behavior with other components, we'd be happy to see a report. |
| Posted: March 16, 2026 10:09 am | ||
Fair enough. This is probably an easier filter to test with, 3 components. My guess is that any bitmap operation after the text component is suspect in draft/preview mode. Can live with it, a partially cosmetic issue. In the mean time I’ll add draft/preview mode to font filters that need it.
| Posted: March 17, 2026 2:56 pm | ||
