Zsolt
Seems like if I add the output of a refraction with a free gradient to another refraction, these weird artifacts appear on the AA pass. The lines coincide with the AA edges. Is there any remedy for this issue? Or should I just render super large and downsample to the final size, like poor man's AA?
Zsolt
Simple way to recreate the issue...
Zsolt
Apparently the Blur is the issue. If you replace it with a Motion Blur with the Directional and Angle set to anything but 0 it doesn't do the artifacts — albeit it's not exactly the same result as a regular Blur. If you set to 0 it behaves as the regular blur and messes it up again.
Seems like a proper application bug, like there's a division by zero somewhere.
Most likely, the AA edges are coming from the Profile Gradient which is used as a source of Refraction. Switching anti-aliasing from Edges Only to All Pixels should help.
