I've attached a sample that shows the latest FF11 editor on the Mac. The lines between nodes are too thin at some magnifications. Looked at another Bomber+ filter in FF7 and the lines were all thicker at this magnification. This is a MacBook Pro 16" from 2019. The filter is Offset Collage.
Rachel, if you tell us your screen resolution and magnification level we can look into the issue.
For this one it say looks like 1536x960 (Catalina). The default is 1792x1120 and the lines still look too thin at this resolution as well. The magnification level is Zoom to Fit of Offset Collage. Another way to compare is to open Cutout Painter into the editor in FF10 vs FF11 at either resolution. The lines are thicker in FF10.
Thanks for the details, we'll look into that.
