Rico
I have a map script that whenever i try to open the input editor it causes an instant crash.
Version: filter forge universal 11.005.62033.5506 release feb 7 2022 13:19 I need to add a couple of new inputs but cant. filter attached. please help. thank you |
| Posted: March 12, 2022 8:06 am | ||
Posts: 3507 |
Sorry to hear about that. If you attached the failing filter we'd surely look into the issue.
| Posted: March 14, 2022 4:49 am | ||
Rico
I did attach the filter to the original question .
I have resolved the issue now, although it was time consuming. I copied the map script alone into a new plugin where I was able to edit the inputs. Then I copied it back into my original plugin and reattached all it's connections. It's not the first time this has happened to me, I think there is a memory access issue causing this crash on map script components. In general there are a lot of crashes that occur when editing plugins, in this version and a few previous ones too, but I have learnt to live with it. It's always a memory access error. Thanks for your help. |
| Posted: March 15, 2022 6:58 am | ||
Rico
Hello again, the issue has re-occurred and this time I cannot work my way around it.
Please see the filter attached. I want to add a few new controls to the script but pressing the input editor button on the map script component causes an instant crash. I tried copying it to a new empty filter and the same issue occurred. Please help. Thank you. GoldenRatio2.ffxml |
| Posted: March 28, 2022 12:21 pm | ||
| Posted: March 28, 2022 12:48 pm | ||
Rico
Thanks Rachel.
I should have added earlier, I'm on Mac OS Monterey 12.0.1 on an M1 Airbook 16GB |
| Posted: March 28, 2022 12:57 pm | ||
Posts: 3507 |
Thanks for your reports, I forwarded the issue to the developers.
| Posted: March 29, 2022 7:55 am | ||
