Redsei Design
Redsei Design
I'm using the projects to render an effect on a number of images.
STEPS USED
1. I create a project.
2. Add a artboard. Pick a filter for the artboard.
3. Change the properties on artboard as follows.
"Background source" I use external video or sequence. Browse to folder and select the first image. (They are all named with a 1,2,3,4,5... afterwords.)
"Animation" is set to automatic.
"Settings" is set to default settings.
4. The select "render animation" under file menu. I select all frames, final quality and channel as default.
Output file(s) is set for image sequence, browsed to NEW location for output.
5. Then I hit RENDER.
I get the same effect applied to the FIRST image 5 times. It only does the first.
What am I missing?
Also I'm on a Mac and don't have the function "Use relative paths to external video or sequence". Could that be a problem?
Redsei Design
Redsei Design, welcome to the forums and thanks for your report.
The rendering issue has been fixed, please re-download and reinstall the latest program build from the Download page.
The "Use relative paths" option is currently disabled and should become available in the next program update.
Redsei Design
Redsei Design
Great thanks-I'll give that a go.
Redsei Design
