Erfinator
Hello... not sure if this is Mac-specific, but it might be...
FF 10.007 Professional Edition
Mac OS 10.14.6
In the help document https://www.filterforge.com/more/help/...Image.html it says:
The dialog is accessible by choosing File > New Image... from the Main Window menu.
However, when I pull-down the file menu, I see what is in the attached png file. Hint: There's no "New Image" option.
The documentation also says:
This menu command is available only in the standalone version of Filter Forge – when Filter Forge is running as a plugin, this command is disabled.
In this case, I am running FF standalone, though I do have it installed as a plugin for Photoshop 2021 (Version 22.5.0). But I don't even have Photoshop running.
I'm probably missing something here... can someone assist?
Thanks!
-Eric
Everything for images in FF10 is now under Image and is called Blank (for new image) or whatever else you need
Erfinator, welcome to the forums and thanks for your report. We'll need to update the help files.
Erfinator
Thanks, that is indeed where it was hiding!
Erfinator
Thanks for the welcome... I was kind of hoping the help files would be updated smile;)
