RobinH
I just updated to 10.007. Now when I try to run FF from PS, the interface comes up, but after I choose my filter and press Apply, I get the spinning beach ball. I've tried waiting a few minutes to see if it was just slow for some reason, but even 15 minutes later, and FF still hasn't started rendering. I've also tried rebooting my computer. I didn't have this problem before the update. Any suggestions?
RobinH
I just tried to run a filter on a super low res image, and that actually worked ok, so it seems like the new FF update is just somehow using way more memory than the previous version. I didn't have any problems with large files before. Not sure what to do, as I really need this to work for a job I'm working on.
If you work with large images it really makes sense to use FF in the standalone mode. It is faster and way more stable.
RobinH
Ah, I did not know that. Thanks for the tip.
13 unregistered users.
