ZAYAR
when program is open you will see all navigation and buttons are in place but when I adjust the size of window some went wrong . WHY ?
Is it BUG or Error ?
+1. I had a window at full screen, grabbed the lower right border and the Draft & Map buttons disappeared as if they were in a fixed position. Workaround: after resizing, close FF10 then reopen it and the buttons will be back to the right place.
Thanks for your reports, the fix should be available in the next program update.
11 unregistered users.
