Rico
I have a plugin with two simple map scripts.
If filter forge quits then my scripts get mangled on to one line and won't load - luckily I had them in a separate editor - so I didn't loose them. Has anyone else had this issue? |
| Posted: September 14, 2020 7:06 am | ||
+1. Same here. I believe there is an issue with the difference between the end of line Windows vs Mac. Windows EOL = CR + LF. Mac EOL = CR. Here's a way to reproduce the problem.
Open FF9 on the Mac Run Image Mandelbrot (or any other filter with a map script) Edit the filter Click on the Map Script component Click the Script Tab Replace the existing script with Mac stytle text (EOL=CR only, did it with MacVIM with fileformat=unix) Click Apply Changes Save Filter Let 3 or 4 thumbnails draw Quit FF Run again... on my MacBook Pro I get script errors in the remaining thumbmails. Math meets art meets psychedelia. |
| Posted: September 14, 2020 7:47 pm | ||
Rico
Hi Rachel, sorry you're getting it to, but also glad I'm not alone.
The good news is that it should be a really easy fix for the devs. Admins - any comments please? |
| Posted: September 15, 2020 5:56 am | ||
Posts: 3507 |
Thank you for the report, it is confirmed and forwarded to the developers.
| Posted: September 21, 2020 12:23 pm | ||
Posts: 3507 |
We have released a fix today that will hopefully solve the issue. Please re-download and reinstall FF9 from the download page.
| Posted: October 12, 2020 8:45 am | ||
